2 members (gswbbc, wilbur53),
139
Mod | | | Forums66 Topics128,035 Posts1,055,446 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2010 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 27 | need help to identify year and type truck i have.it's a 39 or 40 GMC 1 1/2 ton with a pickup bed.model#302 SN#24060 small tag riveted to firewall #984-57002 | | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | Look for the chassis number located on the right hand frame side member above front spring. 1939 numbers are 001 - 10014 , 12001 -12945. Your 302 model number indicates 300 series. | | | | | Joined: Jul 2010 Posts: 27 'Bolter | | 'Bolter Joined: Jul 2010 Posts: 27 | ok i checked out frame number, AC302 2460 . so that makes the truck 1940 ? | | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | AC302: 133" Wheelbase. 2460: 1940 Chassis Serial Numbers 10015-10925 12946-26220 | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Using this chart from oldgmctrucks.com, I read that to be a 1939 serial number. | | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | I would say 2460 falls between the 39 serial numbers 001 - 10014 | | |
