1 members (Hotrod Lincoln),
69
Mod | | | Forums66 Topics128,135 Posts1,056,423 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | I know I saw it someplace. Diagrams showing the brakes hard lines routing. It was this way for these model years, and that way for some other model years... I looked and looked in my brown manual. but I can't remember where I saw them. Links or info help please? thanks. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy scotricker, did you want all the diagrams, or do you want to see the diagram for a specific year and size of truck? | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Well, I think my truck started as a 48. But there are so many Not-48 parts on it now, that I'm not sure what year the brake system is. It might have later brakes, but now I'm not sure. Thanks for checking. | | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | Thanks Tommy, but those pics are Way too new! My truck does not have power brakes, I'm looking for the earlier diagrams, like 48 to 53. thanks | | | | | Joined: Nov 2010 Posts: 14 New Guy | | New Guy Joined: Nov 2010 Posts: 14 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | They are also shown in pretty good detail in the 47-54 Factory Assembly manual as I recall. | | | | | Joined: May 2010 Posts: 132 Wrench Fetcher | | Wrench Fetcher Joined: May 2010 Posts: 132 | thanks Tommy and Brad,
I still think my truck has been set up differently than these pics.
The front line splits and goes around the radiator and over to the other front wheel.
Is that standard? Or did someone do a "custom" installation?
| | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the split across the front is the most common although some have the pattern shown in that LMC drawing, might be partly different years and likely different plants
Bill | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Those lines from LMC will work on your 50. However the original ran under the radiator support in front. It doesn't really matter how you get to each wheel as long as you get the fluid there without leaks.
~Jim
