9 members (55shaker, tclederman, MickeyP, qside, Hotrod Lincoln, Charles in CA, Gdads51, Cletus1950, 1 invisible),
65
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 33 New Guy | | New Guy Joined: Jul 2008 Posts: 33 | The front directional signal along with the inside dashlight is not working (right side). The rear is working properly (flashing). I am not getting voltage to the light or coming out of the firewall plug or the connector underneath the dash. Could it be in the mechanism under the steering wheel? Is there something else I need to check? Parking lights are working fine along with the left hand signal front and rear. Thanks in advance.
Leon Stallings Hartsville, SC 1965 Chevy C20 LWB 1965 Chevy C10 LWB
| | | | | Joined: Nov 2002 Posts: 1,002 Shop Shark | | Shop Shark Joined: Nov 2002 Posts: 1,002 | It could be the turn signal switch, or it could be a bad wire to the firewall connector. The manual says it light blue (LBL) you should have two LBL wires at the inside of the firewall connector. One is the turn signal switch, and the other is the right hand signal light. If the wire is good, I have seen the contact pin in the switch overheat and loose contact.
Larry
I don't own a vehicle that isn't old enough to drink. | | |
