0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
V
V Offline
The front directional signal along with the inside dashlight is not working (right side). The rear is working properly (flashing). I am not getting voltage to the light or coming out of the firewall plug or the connector underneath the dash. Could it be in the mechanism under the steering wheel? Is there something else I need to check? Parking lights are working fine along with the left hand signal front and rear. Thanks in advance.
Leon Stallings
Hartsville, SC
1965 Chevy C20 LWB
1965 Chevy C10 LWB
It could be the turn signal switch, or it could be a bad wire to the firewall connector. The manual says it light blue (LBL) you should have two LBL wires at the inside of the firewall connector. One is the turn signal switch, and the other is the right hand signal light. If the wire is good, I have seen the contact pin in the switch overheat and loose contact.
Larry
I don't own a vehicle that isn't old enough to drink.
