Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
2 members (baldeagle, 1 invisible), 41 guests, and 1 robot.
Topics128,003
Posts1,055,244
Members48,418
#698919 11/28/2010 12:06 PM
Rewired my 53 5 window 216 with a harness from classic parts, upgraded it to 12 volt all went well execpt I have no power going to the gas gague or the instruments lights. Any ideas?
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #698956 11/28/2010 3:18 PM
Charley,
Those leads most likely come from the ignition switch, the fuse box, or the light switch. Short wires/leads are often not included with a reproduction harness (but extra lengths of wires of different gauges are sometimes included).
Light switch
The fuel gauge hot lead comes from ignition switch.
tclederman #698958 11/28/2010 3:30 PM
The gas gauge is fed from the ing. switch when you turn on the ign. switch it feeds power to the gauge
the dash lites are fed from the head lite switch thru the dimmer circuit when you pull the switch out to the frist indent the lites should come on some switches you'll need to hook up a dash lite HOT to that circuit on the head lite switch.
Pete
