| | | Forums66 Topics128,169 Posts1,057,043 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | The front fenders for 1955-56 Chevy pickups are diferent from the 57's. My parts book reads that the front fenders for the 1955-56 and 57 are the same for the 4000 and 6000 series. Is that true? Thanks | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the difference in the light truck fenders is just that the 57 has some mounting holes in the raised ridge around the grill opening, the 5&6 grill fits inside the opening, the 57 sits on top of that surrounding ridge otherwise identical and can be interchanged ... 4100 and up = 1.5T and up - different fenders than the light trucks, useing about the same grill all years and it fits inside the opening, so yes all 3 years the same
take a walk thru the gallery and note the difference in light/heavy trucks of those years
Bill | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Actually the difference is in the wheel well opening with the big trucks the 57s opening is 1 inch forward compared to the 55 and 56 this is true with the front springs as well 55 and 56 the axle pin is centered on the spring 57 is one inch to the front centering the wheels in the well. This allows for a larger steer tire to be used on a 57 without hitting the fire wall when turning.
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | HevyHauler is correct, almost...the 1957 front axle was moved 2-1/2" forward making the 4000 & 6000 fender wheel openings larger than the 55-56 fenders. If you measure across the bottom of the wheel opening the 55-56 fenders are about 39" while the 57 is about 41.5". Mike B  | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | Thanks for the correction Mike.  That’s my life story though almost right HA HA  | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Thanks for the help guys!!!!!!! | | |
