4 members (delwrench, Shaffer's1950, NJC, Gdads51), 82 guests, and 3 robots.
Topics128,162
Posts1,056,951
Members48,458
#698881 11/28/2010 5:09 AM
The front fenders for 1955-56 Chevy pickups are diferent from the 57's. My parts book reads that the front fenders for the 1955-56 and 57 are the same for the 4000 and 6000 series. Is that true? Thanks
1955 Chevrolet 6100 Wrecker
More pix on Flickr
"A good mechanic doesn't know everything, but he can figure out anything". ~ --My DAD
1955 Chevrolet 6100 Wrecker Video
1955 Chevy 6100 Wrecker Update Video
the difference in the light truck fenders is just that the 57 has some mounting holes in the raised ridge around the grill opening, the 5&6 grill fits inside the opening, the 57 sits on top of that surrounding ridge otherwise identical and can be interchanged ... 4100 and up = 1.5T and up - different fenders than the light trucks, useing about the same grill all years and it fits inside the opening, so yes all 3 years the same
take a walk thru the gallery and note the difference in light/heavy trucks of those years
Actually the difference is in the wheel well opening with the big trucks the 57s opening is 1 inch forward compared to the 55 and 56 this is true with the front springs as well 55 and 56 the axle pin is centered on the spring 57 is one inch to the front centering the wheels in the well. This allows for a larger steer tire to be used on a 57 without hitting the fire wall when turning.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
HevyHauler is correct, almost...the 1957 front axle was moved 2-1/2" forward making the 4000 & 6000 fender wheel openings larger than the 55-56 fenders. If you measure across the bottom of the wheel opening the 55-56 fenders are about 39" while the 57 is about 41.5".
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Thanks for the correction Mike. dang That’s my life story though almost right HA HA grin
user
Thanks for the help guys!!!!!!!
More pix on Flickr
