| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | When I attempted to mate my 1952 transmission to the bellhousing I discovered I had an "early" bellhousing with narrower transmission mounting holes. It also has holes for mounting the pedal assembly. I have since rectified my situation but would like to sell the early bell housing. The best I can determine from searching is that it will fit any 216, 235, or 261 engine. I also think it will fit any truck from 1940-53 but not really sure about that. The transmissions that will fit I am unsure about. Only 1940-46? Are these the same years that mount the pedals to the bell housing? Any confirmations or corrections would be appreciated.
Chuck | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The bell housings that have a a provision for pedal mounts were used up till 1946. so if it bolts to a 216/235 it is a 1937-46.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | Dave- Thanks for that info as well as all the other help you provide to this forum. Chuck | | |
