4 members (greenie-reddy, pauld, 2 invisible), 85 guests, and 2 robots.
Topics128,266
Posts1,058,368
Members48,485
#69880 12/11/2006 9:37 PM
I'm looking to find out if there are sources for a correct 4 bbl intake for my '66 283. I would like to know the correct casting number if someone can let me know.
thanks a lot in advance. by the way what is the tiny tubing going into the intake on my existing 2bbl. Is this the vacuum line? There is also a rubber line going to a fitting into the back of the intake to the carb. What is this?
Thank you for your help and assistance.
Gary
GS
#69881 12/11/2006 10:49 PM
To the best of my knowledge, I don't think you are going to find the correct 4 Bl intake for a 66 283 in a truck as they did not offer a 4 bl until about 69 and that was a 350. Probably the ones you have seen on other trucks are either aftermarket or from a passenger car. There is one metal line with a vacuum hose attached that goes from the carb to the distributor vacuum advance. There could be a line to the choke also. Fred
#69882 12/11/2006 11:30 PM
Riding in the Passing Lane
There is also a PCV hose. I believe the pcv valve is on the back of the carb. & a hose runs to an adapter at the back of the intake behind the dist.
1972 Chevy c10 Cheyenne Super
