8 members (pauld, lumbersawyer, Gdads51, frogfarmer, J Lucas, carbking, Charles in CA, 1 invisible),
99
7
Mod | | | Forums66 Topics128,264 Posts1,058,358 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#69880 12/11/2006 9:37 PM | Joined: Oct 2006 Posts: 84 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 84 | I'm looking to find out if there are sources for a correct 4 bbl intake for my '66 283. I would like to know the correct casting number if someone can let me know. thanks a lot in advance. by the way what is the tiny tubing going into the intake on my existing 2bbl. Is this the vacuum line? There is also a rubber line going to a fitting into the back of the intake to the carb. What is this? Thank you for your help and assistance. Gary
GS
#69881 12/11/2006 10:49 PM | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | To the best of my knowledge, I don't think you are going to find the correct 4 Bl intake for a 66 283 in a truck as they did not offer a 4 bl until about 69 and that was a 350. Probably the ones you have seen on other trucks are either aftermarket or from a passenger car. There is one metal line with a vacuum hose attached that goes from the carb to the distributor vacuum advance. There could be a line to the choke also. Fred
#69882 12/11/2006 11:30 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There is also a PCV hose. I believe the pcv valve is on the back of the carb. & a hose runs to an adapter at the back of the intake behind the dist. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
