1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
When I attempted to mate my 1952 transmission to the bellhousing I discovered I had an "early" bellhousing with narrower transmission mounting holes. It also has holes for mounting the pedal assembly. I have since rectified my situation but would like to sell the early bell housing. The best I can determine from searching is that it will fit any 216, 235, or 261 engine. I also think it will fit any truck from 1940-53 but not really sure about that. The transmissions that will fit I am unsure about. Only 1940-46? Are these the same years that mount the pedals to the bell housing? Any confirmations or corrections would be appreciated.
Chuck
The bell housings that have a a provision for pedal mounts were used up till 1946. so if it bolts to a 216/235 it is a 1937-46.
My Blog
Dave- Thanks for that info as well as all the other help you provide to this forum.
Chuck
