5 members (Johnny N, tesa, Chris's 46 / 515, Gray_Ghost, Youngin' Tut 59), 76 guests, and 2 robots.
Topics128,076
Posts1,055,924
Members48,430
#698004 11/25/2010 1:59 AM
Does anyone know if they make a Power Trac that will work in the original enclosed rear end for the 1948-53 1/2 ton trucks?? Thanks John
Power Trac? isn't that a lawn mower technology? if you mean positraction or limited slip, might find a way, but not just a drop in
squeeze #698042 11/25/2010 3:23 AM
Short answer, no. Not much of anything in a locking type differential available until you get to the '63 and up with the 12 bolt rear, and even then it has to be the 30 spline ('65) axle.
Bill Burmeister
LONGBOX55 #698066 11/25/2010 4:06 AM
Okay thanks, I had seen on their website they only went back to 1964 or 65 trucks, but thought maybe there might still be a unbit that would fot the older housings. The 48-54 1/2 ton axles used the same housing didn't they through at least '59 minus the enclosed drive shaft after 54??
I will say the site has changed quite a bit since I had last been on here.....
More or less, yes the housing is the same. I think there might be slight width difference. The '60-'62 also used a simlar housing, but I think it might be even wider, plus it's setup for the coil spring suspension on 2wd trucks. There was a Posi option on the '60-'62 alxe, but it was very rare, and no parts are being made for it, although there is still a listing for replacment clutch packs for them through the GM dealers.
Bill Burmeister
