| | | Forums66 Topics128,282 Posts1,058,494 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | who has done a power steering conversion on these 60-66 trks? i need a info source on diy project.currently use the original manual set so we need to know what p.s. gear box to use brackets,pump etc. | | | | | Joined: Feb 2007 Posts: 230 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 230 | Did my '62 about 2 years back. Suggest that you consider buying a complete kit which will include all the stuff including the PS lines. There are probably vendors on this site and others like Classic Industries, LMC, etc that have the kits. This is what I did. Although a kit will cost you more than cobbling together your own parts, everthing you need will be there, parts will be new or rebuilt, and will fit. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | I went the cheap way, bought a REZ kit from Classic Parts of America & used a box from a donor 1980 C10. | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Dave, I did the switch (upgrade) last year, here are the pictures. http://rides.webshots.com/album/571837084bSxNPfDo not buy the REZ kit, it is really made for the 63-66 frame. It will not bolt up the best way. IF you have the 60-62 you will need to get the Classic Performance Products (CPP) kit, you also get the steering shaft adaptor, which you will need to shorten the shaft. Jake
| | | | | Joined: Sep 2009 Posts: 118 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 118 | has anyone ever used the cpp kit on a 60-62 3/4 ton? | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | | | | | | Joined: Nov 2010 Posts: 109 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2010 Posts: 109 | There are some great tech articles at this website and pictures of installing power steering just as you asked. http://www.classicperform.com/tech.htm | | | | | Joined: Oct 2010 Posts: 40 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 40 | | | |
