4 members (originalchuck, TooMany2count, Chip O, Hotrod Lincoln), 78 guests, and 2 robots.
Topics128,024
Posts1,055,392
Members48,422
#696312 11/19/2010 2:18 PM
who has done a power steering conversion on these 60-66 trks? i need a info source on diy project.currently use the original manual set so we need to know what p.s. gear box to use brackets,pump etc.
Did my '62 about 2 years back. Suggest that you consider buying a complete kit which will include all the stuff including the PS lines. There are probably vendors on this site and others like Classic Industries, LMC, etc that have the kits. This is what I did. Although a kit will cost you more than cobbling together your own parts, everthing you need will be there, parts will be new or rebuilt, and will fit.
I went the cheap way, bought a REZ kit from Classic Parts of America & used a box from a donor 1980 C10.
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Here's a thread that provides several different opinions and how-to articles:
http://67-72chevytrucks.com/vboard/showthread.php?t=346034
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Dave,
I did the switch (upgrade) last year, here are the pictures.
http://rides.webshots.com/album/571837084bSxNPf
Do not buy the REZ kit, it is really made for the 63-66 frame. It will not bolt up the best way. IF you have the 60-62 you will need to get the Classic Performance Products (CPP) kit, you also get the steering shaft adaptor, which you will need to shorten the shaft.
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
has anyone ever used the cpp kit on a 60-62 3/4 ton?
Yeah I did see above.
There are some great tech articles at this website and pictures of installing power steering just as you asked.
http://www.classicperform.com/tech.htm
Jon S
Las Vegas NV
1966 GMC Suburban 305V6
Psalm 66 "Make a joyful noise"
http://i12.photobucket.com/albums/a205/gvdobler/0205011645b.jpg
thanks john!
