| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Does anyone know if they make a Power Trac that will work in the original enclosed rear end for the 1948-53 1/2 ton trucks?? Thanks John | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Power Trac? isn't that a lawn mower technology? if you mean positraction or limited slip, might find a way, but not just a drop in Bill | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Short answer, no. Not much of anything in a locking type differential available until you get to the '63 and up with the 12 bolt rear, and even then it has to be the 30 spline ('65) axle.
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Okay thanks, I had seen on their website they only went back to 1964 or 65 trucks, but thought maybe there might still be a unbit that would fot the older housings. The 48-54 1/2 ton axles used the same housing didn't they through at least '59 minus the enclosed drive shaft after 54??
I will say the site has changed quite a bit since I had last been on here..... John | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | More or less, yes the housing is the same. I think there might be slight width difference. The '60-'62 also used a simlar housing, but I think it might be even wider, plus it's setup for the coil spring suspension on 2wd trucks. There was a Posi option on the '60-'62 alxe, but it was very rare, and no parts are being made for it, although there is still a listing for replacment clutch packs for them through the GM dealers.
