Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
5 members (TexasFarmTruck, RoadsScholar, 2-Ton, Wayne67vert, 1 invisible), 157 guests, and 6 robots.
Topics128,282
Posts1,058,497
Members48,490
#69786 12/10/2006 1:28 AM
Z
Z Offline
1. WHAT size are the brake shoes on a 41-46 3/4 ton truck?
My rears are 11 inch and the front ones are smaller, about 9 inch, is this right?
2. Where is the chassis number located on this beast?
Any help appreciated
"After you skin yer knuckles, Mr Shifter ain't yer friend any more."
1942 Chevy 3/4 ton
Photo Site
1946 Chevy 5 window coupe/ute (new stray)
2000 Nissan Patrol 4x4 4.5l turbo diesel
#69787 12/10/2006 3:56 PM
Riding in the Passing Lane
I,ve got an old brake parts book but it doesn,t go back that far. Something has been changed though that it way to small of brakes even for a half ton.
1972 Chevy c10 Cheyenne Super
#69788 12/10/2006 4:36 PM
3B Offline
Hy Zacca, my truck salesman's data book lists the brakes as 11" x 1 3/4" front and rear with standard brakes. There is an option for the rear which is 14" x 2", hope that helps.
#69789 12/10/2006 7:53 PM
The stock shoes on a 1946 3/4 ton are as follows:
1.75" x 11" on the front drums
2" x 12" on the rear drums
I'm not sure what the drum sizes are, beyond the fact that the front drums are smaller than the rears.
The Body Serial Number is located on the cowl on the passenger's side. It should look something like this: 21DR-C3490 (that is mine).
The number at the beginning is the plant where assembly occured, the two letter code (DR) tells you what size truck you have, the single letter code (C) is the month of manufacture, and the number is the serial number, starting at 1001.
#69790 12/18/2006 7:46 AM
Zacca,
I have a 1953 3/4 ton and just finished with the brakes. As I understand and if you have a shop manual to consult, the rear shoe is supposed to be larger than the front shoe. This would be the case on both axles. I think it has something to do with the amount of force being applied by the brake mechanism and how it applies that force. The shop manual makes note of this and I am glad that I had it b/c I wasn't paying attention that closely when I dissassembled my brakes. Good luck
Whad you do?!?
Shane
1953 Chevrolet 3600
