| | | Forums66 Topics128,035 Posts1,055,443 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | I installed disc. Brakes on my “54” with a new master cylinder and booster from CPP and now I am having trouble getting a good peddle. I bench bled the master cylinder and have used both a hand pump and manual bleeding to get the air out but just cannot seem to get a solid peddle. I have read in some post about “valves” in the lines to keep the fluid from going back to the master cylinder since it is below the level of the calipers I know this is a common swap with the master cylinder/booster so can someone tell me what else to check, what have others done if they had this problem? Thanks
| | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | They are called residual valves. available at speedway and others for about $15 each
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | a 2lb. residual valve to the discs and a 10lb. residual valve to the drums. | | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | Are these valves put on each wheel or inline somewhere? | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | They are put on each line out of the master cylinder. one for the front and one valve for the rear brakes. | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Here is some info on the valves link I was able to get good pedal with out installing the residual valves. Good Luck
| | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | I was told by CPP that the proportioning valve should take care of bleed back into the master cylinder that I probaly need to bench bleed my master cylinder again? Is anyone running the residual valves and proportioning valve together? Thanks | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | You can run both as they provide different functions. The residual valves you already know about,whereas the proportioning valve provides balance between the front and rear circuits. Due to the lighter rear end on most pick-ups when empty it's much easier to lock up the brakes in an emergency stop. The proportioning valve (usually) reduces the pressure to the rears to prevent this. There are adjustable ones available to allow you to tune your system to your personal needs.
1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | I run both, no problems with soft pedal. I did need to bench bleed the master cylinder a second time. | | | | | Joined: Nov 2009 Posts: 38 New Guy | | New Guy Joined: Nov 2009 Posts: 38 | Can someone tell me what the fitting is that I need to connect the residual check valve to the proportioning valve? Thanks | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | It should be piped in line like in this pic from jockbolters web site jocks pic here is the adapter link The link is just for reference, youll have to determine the size you need You should be able to get the fittings from your local auto parts. I got all my brake line fitting from my local Carquest Good Luck | | |
