3 members (Brian Moore, klhansen, 2-Ton), 87 guests, and 2 robots.
Topics128,037
Posts1,055,465
Members48,422
#69776 12/09/2006 9:06 PM
Other than power, are there any advantages between the 270 & 261 for regular open road use? I've had no 261 experience.
#69777 12/09/2006 9:28 PM
Riding in the Passing Lane
The 270 is a GMC engine & the 261 is Chevy. The 270 is a more rugged engine.
1972 Chevy c10 Cheyenne Super
#69778 12/10/2006 3:10 AM
The differences include the alloy used in casting the block. The GMC was made of better stuff.
#69779 12/10/2006 7:23 AM
Thanks - What about rpm, torque, economy etc?
#69780 12/11/2006 1:34 AM
The 270 should top the list in all of the above. The advantage of the 261 is parts availability. I imagine in New Zealand it may be hard to find parts for either engine. Of course a 302 gmc would out perform the others and bolt right in to your cckw.
#69781 12/11/2006 5:08 AM
I think for fuel economy it would be about a wash, and would depend on how well your carburetor is tuned. The AA-1 carb on a 302 (might be on a 270 also) or a Carter would generally outperform a Rochester B on a 261, although you could swap a Carter to a 261. You might also want to run vacuum advance, some of the big GMC's don't have one. 261's do.
Paint & Body Shop moderator
#69782 12/11/2006 10:22 AM
Still plenty of 216's, 235's & 270's over here tucked away in sheds, and rebuilds are no problem, but I don't personally know anyone with a 261 - maybe it wasn't a common option imported here.
The 270 in my CCW is still fine, I was wondering about a 261 for a lighter truck. Sounds like another 270 is still the way to go though - Thanks again
