0 members (), 136 guests, and 7 robots.
Topics128,077
Posts1,056,032
Members48,433
#697635 11/24/2010 3:24 AM
Anyone have the specs on the bleeder screws for the brake system on a '66 C50?
The one on the slave cylinder takes a 7/16 wrench and the ones located on the wheel cylinders take a 3/8. I want to replace a couple but don't know the thread size/pitch.
Help?
Brian
3B Offline
Hy Brian Lohnes, according to my parts book there are different part numbers depending on whether you are looking for front axle ones or rear axle ones, and then the size of the diff makes a difference on the p/ns as well.
I can tell you I'm looking for the one on the slave cylinder (Hydravac) and one for the rear axle, which is a single speed 15,000lb piece.
3B Offline
Hy Brian Lohnes, it took a bit of looking, but I think both of them have the same thread and length. They do have two different o.e.m. p/ns the wheel cylinder screw is p/n 5455122, it has 3/8" X 24 t.p.i. X 1 1/64", the Hydrovac screw is o.e.m. p/n 2261467 also 3/8" X 24 t.p.i. X 1 1/64", so I guess the difference in the part number is the size of the hex. Some crosses for those part numbers are Carlson H9402
Bendix 94005
FM 3203
Quick Brake 107
United 6858
Wagner F6858, hope that helps.
You are THE MAN!
