0 members (), 89 guests, and 4 robots.
Topics128,271
Posts1,058,313
Members48,485
#697598 11/24/2010 12:45 AM
I'm in the process of adjusting the hood of my 1957 Chevy pickup. I have the front aligned and the back bumpers are adjusted so the back of the hood aligns evenly with the cowl. It also appears to be aligned straight, front to back. However, when I open and close the hood, the back sits too high. When I press down, the hood sits correctly. I'm guessing the hood springs may be weak, or is there an adjustment for that?
not the springs, the hinges have slightly worn pins, a pretty common condition for many years, you really need new ones to fix that
Donsz,
Go to the "TECH TIPS" section of the bolt ...there is a proceedure there for fixing your problem.
You need a 2X4 and bought 10 minutes of your time to fix the dreaded REAR HOOD RISE.
LOOK under "general body work" 1st. topic.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Thanks for your responses, Tim, I'll try the Tech Tips method (I have more than ten minutes - I usually take longer than normal for anything it seems). I should have checked the Tech Tips, thanks for the prompt. If that doesn't work, I'll buy a new set as Bill suggests
Tim / Don - that tip is for AD's, the TF is a different animal
I have the same problem with my 59. I just boxed mine up to send to this guy. www.hoodhingerepair.com
He done them for my Chevelle and does great work. He can also powdercoat them if you wish.
Darren
OOOPS, sorry didnt catch the yr. on that truck, just saw the rear of the hood sticking up ? and remebered the frustartion I had getting mine on my AD to lay flat until I found the TECH TIP.
Again sorry for steering ya the wrong way.
1952 Chevy Shortbed
