0 members (), 234 guests, and 9 robots.
Topics128,078
Posts1,056,052
Members48,433
#696925 11/21/2010 5:58 PM
just got my cab of and trying to find the rear cab mounting shackles on a 51 chevy. i can find the cab mounting kits but no shackles that are under the cab. thank you guyyoung
I believe they sell kits with the rubbers but I haven't seen the actual shackles for sale.
1951 1 Ton Completed
This is what a factory shackle set-up typically comes with, the vendors don't sell the extra shims and plates with theirs. This is for a 1/2-ton they have the offset holes you see. COE mounts are different and the other 3000, 4000, 6000 Series trucks use a straight hole alignment rather than offset where they attach to the frame that style is not reproduced. I sent you a PM nice to see another Utah Bolter on the boards.
http://good-times.webshots.com/photo/2235943390102454676FUuGUv
