| | | Forums66 Topics128,078 Posts1,056,046 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 26 New Guy | | New Guy Joined: Mar 2010 Posts: 26 | just got my cab of and trying to find the rear cab mounting shackles on a 51 chevy. i can find the cab mounting kits but no shackles that are under the cab. thank you guyyoung | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I believe they sell kits with the rubbers but I haven't seen the actual shackles for sale. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | This is what a factory shackle set-up typically comes with, the vendors don't sell the extra shims and plates with theirs. This is for a 1/2-ton they have the offset holes you see. COE mounts are different and the other 3000, 4000, 6000 Series trucks use a straight hole alignment rather than offset where they attach to the frame that style is not reproduced. I sent you a PM nice to see another Utah Bolter on the boards. http://good-times.webshots.com/photo/2235943390102454676FUuGUv
