1 members (baldeagle), 42 guests, and 2 robots.
Topics128,037
Posts1,055,466
Members48,424
#696779 11/21/2010 3:13 AM
Which is easier for a novice?
#1 Swap out the rearend or
#2 Change the the gears in the rear end.
Have a clunking noise when backing up u-joints seem ok.
Mark
blue67fleetside #696879 11/21/2010 3:24 PM
Changing an entire rear is easier than setting a ring gear and pinion. Have you had your U joints apart. There isn't much you can see from the outside.
crenwelge #697038 11/22/2010 1:04 AM
No I didn't take them apart.
blue67fleetside #697350 11/23/2010 3:55 AM
Ujoints are fairly cheap. If yours are old and something clunks, you have to open them to check them. Might as well put in new ones and know you won't need to worry about them for a long time.
