3 members (TUTS 59, Jon G, 1 invisible), 163 guests, and 0 robots.
Topics128,157
Posts1,056,874
Members48,456
#696144 11/18/2010 9:54 PM
My grand dad was telling me the other day when he looked at my 52 chevy 3600 that a lot of guys back then ran 8 volt batteries instead of 6 because they got better starter performance that way. Have any of you guys heard or have done that? Also where is the best place to purchase a 6 or 8 volt auto battery?
Your local auto parts store will either have them in stock or can get them. Stick to 6 volt, proper tuning and maintenance is all it needs.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Stay away from 8 volt batteries! I run a electrical shop, and this never works very well or for very long. First, if your starter is cranking too slowly, fix the problem. Second, to keep an 8 volt battery fully charged, your voltage regulator must be set at around 9.5 volts which will greatly reduce the generator and regulator life. If everything is right with your electrical system, your engine will start in any weather using 6 volts. Remember, there was a time when 6 volts was all there was. I hope this helps.
MLT Offline
This is great advice, and reminds me I need to check the mechanics work on the regulator that was installed just before I bought my 51 from my grandpa.
@ OP: My grandpa had put in an 8v years back when he said she " didn't like to start". When I got it, that's the first thing I did. Went to napa, they had a 6v for ~ 80.00. once I put in a properly sized bat cable (2/0), I was good to go. A 6v is all you need n
thanks for the help. Great advice!
