7 members (MickeyP, TGP, 68ironhead, Nhluvstruck, Otto Skorzeny, treegrower, Peggy M),
56
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,090 Posts1,056,016 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | I did a search and did not find the answer for my question. Picked up an S 10 tank for my '48 today, and obviously it has several hose connections, and I want to hook up a suction line only. Can I just plug off the remaining 3 lines, while still using the vent line? And what precautions should I take to make sure the electrical wires and connections do not create a spark? | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | I plugged the unused fittings on my tank by finding an appropriate size bolt and sliding into the rubber line and putting a hose clamp to hold the bolt in place.
As far as electrical wires I use crimp fittings and electrical heat shrink tubing. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | All those extra tubes/holes are for fuel injected engines. Plug them up and you will be ok.
~Jim
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | BTW what electrical connections are you talking about?
~Jim
| | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | bowtiefan,
By looking at your blog I am assuming you are running the straight six only with an s-10 gas tank right? I have a similar situation, only I am running a 350 engine. One problem you will have is the fuel gauge. What I ultimately want to do is adapt the original sending unit into the s-10 tank with an adapter plate. That way the original gauge will read properly. Reason why it won't is two things. 1. the ohms in the sending units are different, 2. the original gauge is 6 volt (easy fix there with a reducer and or an aftermarket 12v gauge) But, having the gauge as 12v still might not get you any readings from the s-10 sending unit because the ohms are different. I have not found any straight answer on getting all three equations to work.
As for your fuel lines. I am not certain because I have not fiddled with the Straight six and or older engines yet (even though I have them). So I don't know if they have return lines. I can't see how or why they wouldn't but it sounds like they don't. The s-10 tank has three smaller lines on it, one is return, one is fuel and one is vent I believe.
The electrical stuff. I am assuming you wanted to hook up your sending unit to the s-10 tank right? again issues from above. But if you try that out, let me know how it goes, and or I'll let you know as I am hooking my tank up very soon. Again I feel like I will have to adapt the OG sending unit into the s-10 unit. You shouldn't need any of the electrical stuff from the s-10 tank if you aren't concerned with the fuel gauge at this point. Your engine has a mechanical pump and will pump the fuel that way. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 |
Ok, back to the sender. I had my head up......I wasn't thinking of the fuel pump that was on the sender. So that has been removed, and I now understand that the sender and gauge probably are not compatable. The original sender was shot on the tank, so I may have to buy a replacement '48 sender and attach it to the S10 tank opening. May take some modification.
| | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | bowtiefan, Yeah you can get aftermarket senders from say classicparts.com http://www.classicparts.com/Sending-Units/products/837I am probably going to do the same thing. The opening on the s-10 tank is a far larger diameter, so yeah an adapter plate is going to be needed. I did measure the depth of the tanks one time. I think they are pretty close if I remember. So hopefully it will work. I know the depth of the tank makes a difference. keep us posted on what you do. I will also keep you guys posted. Again though, I am using a 350 in mine with an s-10 tank with the original fuel gauge, 12v system. | | | | | Joined: Apr 2010 Posts: 35 New Guy | | New Guy Joined: Apr 2010 Posts: 35 | I have also come to find out the original tanks are 17.5 gallons and the s-10 tank is 16 gallon. So I am not sure how much a difference that will make. | | |
