| | | Forums66 Topics128,193 Posts1,057,241 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 15 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 15 | Hello-
I have a 1958 Chevy Viking 6400 with two-speed rear axle. Anyone know where I can get the internal seals for the vacuum shift assembly that bolts onto the two-speed rear axle? I bought a new diaphragm already. Need the felt packing, and top and bottom seals. Underside of diaphragm has oil in it. I have a book at home with the part numbers. My wife works at a GM dealership, and is having her parts guys check on them. But I wanted to see if any fellow Big Bolt owners have went through this yet. Thanks in advance!
| | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | This might be very helpful , i think there is also a diaphragm on the back side of the speedometer too.
I think Ii will be in need for gaskets, or seals, for both.
So please distribute if you can get the part numbers. My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Jul 2006 Posts: 15 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 15 | These are the part numbers for the two speed chevrolet vacuum shift assembly on 2 speed axles for 1956-1958 in order to rebuild it:
Diaphragm- 3847058 GM# 374451 Bendix#
Whole assembly- 3874330 GM# 2504299 Bendix# Cylinder and Boss assembly- 3847055 GM# 374460 Bendix# Shell and seal assembly- 3721330 GM# 377271 Bendix #
Piston rod seal- 3721328 GM# 374534 Bendix# Diaphragm seal- 31/32 I.D.x1.5 O.D.x 7/32 Thick GM# 3705847
Diaphragm assembly gasket- 3705848 GM#
Diaphragm felt packing- 3705845 GM#
Packing retainer- 3705846 GM#
Piston rod seal gasket- 3723038 GM# 377416 Bendix#
Piston rod- 3721350 GM# 377274 Bendix#
Many of these parts are still sitting in GM dealerships. I had my wife check with her parts guy, and the parts I needed were available, but scattered throughout the US. I would have to pay the shipping to get them to her GM dealership, so cost will be pricey. Hope this helps.
Turns out my diaphram was bad, so I just replaced that. Shifts much quicker now and easy.
| | | | | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Any idea if these parts can fit my '54 GMC 350 vacuum 2 speed too? Mine drops out of High if I try to cruise it at road speed,from losing it's vacuum. Back out of the throttle or downshift one gear,all's well. I suspect it's just a couple of hose leaks,but might be worth having some parts on hand,just in case. Speed | | | | | Joined: Jun 2010 Posts: 384 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 384 | If any leaks or mafunction, is the rear gear defaulting on LOW or HIGH ? My Chevy Viking 1959Ulf Hedlund. Eskilstuna. Sweden [email protected]Also: Ford Galaxie 4 dr 1959 Ford Custom 4 dr 1964 Ford Mustang GT 2005
| | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | If any leaks or mafunction, is the rear gear defaulting on LOW or HIGH ? I'm also curious about the answer to this question. I'm assuming that it pertains to whatever is in my '55.2 frankentruck, of course. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | The rear normally stays in which ever range you leave it in, but if there is a default it would be LO range as that's the down position on the actuator plunger. Mike B  | | | | | Joined: Mar 2016 Posts: 170 'Bolter | | 'Bolter Joined: Mar 2016 Posts: 170 | I had assumed it was a vacuum actuated/spring return type unit. Good to know that's not the case. | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | There is no return spring involved... Mike B  | | | | | Joined: Jul 2007 Posts: 28 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 28 | Do you know if any of these part numbers were used in a 1953 two ton vacuum shift? | | | | | Joined: Mar 2004 Posts: 6,236 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,236 | Exactly what parts do you need? The Diaphragm is the same, but that might be about all... Group 5.635 Mike B  | | |
