2 members (carbking, TUTS 59),
108
Mod | | | Forums66 Topics128,029 Posts1,055,416 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | dont know if i have a 283 or a 327 nos on head are fo4o5wa | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | need the casting numbers to identify things, head casting numbers aren't as useful as block ... block casting number on the driver side rear where the bellhouse bolts on, 7 digit number starting with 3 ... or get the number stamped onto the pad that's at the bottom front of the pass side head that'll tell application
Bill | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | THE nos i gave came from pad on block in front of pass side head | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | that code could be a few different blocks, including a 283, still need block casting numbers [and you've got letter 'o's in place of number '0's - F0405WA = Flint, April 5th, 65,68 or 69 truck] Bill | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | then it would be a 283 as they didn't install 327's until 66 ron | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | then it would be a 283 as they didn't install 327's until 66 ron unless it's from a 68 or 69 or ..... block and head casting numbers tell the story Bill | | | | | Joined: Aug 2007 Posts: 462 'Bolter | | 'Bolter Joined: Aug 2007 Posts: 462 | THIS engine is in a 1968 truck but not original engine.I tend to believe it is a 283 the color is grey i can read the high torque sticker but cant see 283 or 327. I know the grey color is correct color for the 283s. I will get the nos off back of engine | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 | then it would be a 283 as they didn't install 327's until 66 ron I thought it was 1962.... 1962 thru 1967 car & truck block 3789817 & 3782870
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Cars got the 327 in '62, but light trucks didn't get it until '65, and then only on 3/4 and 1 tons, 1/2 ton didn't get the 327 until '66. On the answer at hand, the block stamping code is for a 307, which took the place of the 283 in '68. There was a WA coded 283 in '67, so we really need the date code from the block to be certain.
Bill Burmeister | | |
