5 members (32Fordpuchoptop, Otto Skorzeny, Mike B, Bill Hanlon, bluechev), 48 guests, and 2 robots.
Topics128,030
Posts1,055,418
Members48,422
#695831 11/17/2010 11:19 PM
dont know if i have a 283 or a 327 nos on head are fo4o5wa
need the casting numbers to identify things, head casting numbers aren't as useful as block ... block casting number on the driver side rear where the bellhouse bolts on, 7 digit number starting with 3 ... or get the number stamped onto the pad that's at the bottom front of the pass side head that'll tell application
squeeze #695852 11/18/2010 12:08 AM
ok will do thank you
THE nos i gave came from pad on block in front of pass side head
that code could be a few different blocks, including a 283, still need block casting numbers [and you've got letter 'o's in place of number '0's - F0405WA = Flint, April 5th, 65,68 or 69 truck]
then it would be a 283 as they didn't install 327's until 66
ron
ron
unless it's from a 68 or 69 or .....
block and head casting numbers tell the story
THIS engine is in a 1968 truck but not original engine.I tend to believe it is a 283 the color is grey i can read the high torque sticker but cant see 283 or 327. I know the grey color is correct color for the 283s. I will get the nos off back of engine
ron
I thought it was 1962....
1962 thru 1967 car & truck
block 3789817 & 3782870
-Tom
1950 Chevy 3100 w/ 1956 235
Cars got the 327 in '62, but light trucks didn't get it until '65, and then only on 3/4 and 1 tons, 1/2 ton didn't get the 327 until '66.
On the answer at hand, the block stamping code is for a 307, which took the place of the 283 in '68. There was a WA coded 283 in '67, so we really need the date code from the block to be certain.
Bill Burmeister
