3 members (TUTS 59, Rusty Rod, fonz8261), 60 guests, and 3 robots.
Topics128,026
Posts1,055,400
Members48,422
#695596 11/17/2010 3:34 AM
I have a '39 3/4 ton pickup with the original wheels. It will take a lot of work to make the old wheels clean and useable. Does anyone know from what newer trucks I can get wheels that will fit? How late the '39 bolt pattern was used? Maybe where I can get cheap wheels??
Gary
ggfossen #695617 11/17/2010 4:17 AM
One way to use the original is to have them powder coated. That works great.
Monroe McKill
Monroe McKill #695675 11/17/2010 1:00 PM
Are you talking about single piece wheels or multi piece? If they are multi piece and they are badly rusted, they should be junked.
1951 1 Ton Completed
truckernix #695694 11/17/2010 2:55 PM
So What is the bolt pattern? By newer do you mean modern or just newer stock type.
gotgasd #695727 11/17/2010 5:07 PM
To all,
The originals are single piece artillery type. I think they are salvageable, but I want to install a set of later model OE steel wheels so as to make the finished chassis a roller. I need to move it in the shop. The originals will take some time and work for which I am not yet equipped. I have one that is a plain steel rim of recent build (perhaps from the 80s), but I do not know from what vehicle it came.
The current original wheels are 15" with six lugs, and whatever the standard spread would be for a '39.
I think one of the more recent Toyota rims will fit, but I do not know which. I also suspect that Chev used the same bolt pattern into more modern times, but I don't know on which trucks.
I have tried to find swap charts, but to no avail. I will check with the local tire place later in the week, but had hoped to have enough ammo to scronge the junk yard first.
Thanks.
Gary
ggfossen #695730 11/17/2010 5:15 PM
You are correct. Toyota and Chevy wheels into the late 1980's are the same six lug pattern. To avoid steering problems, get the narrowest wheel you can find and/or make sure the offset doesn't put the tire into anything. I'm guessing you will be looking in salvage yards as a source.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Summit Racing has a great selection of after market wheels.I would look there first.
dale937 #695776 11/17/2010 8:06 PM
Yes, either salvage yards, or tire shop take-offs. Cheap is the word of the day...or life time. I need to stick closely to the originals, as I intend to re-mount the tires onto them when I have them blasted and painted, and whatever else has to be done to them.
I will check for late model chev and toyo.
Gary
gotgasd #695871 11/18/2010 1:22 AM
I will poke around town on Friday, and see what surfaces. Les Schwab may have some reasonable take-offs, and we have a couple of salvage yards.
Gary
Last edited by cletis; 11/18/2010 7:00 AM. Reason: Removed response to parts offer
ggfossen #695884 11/18/2010 1:44 AM
1987 is about as new as you can go on Chevrolet wheels, the later trucks use a much deeper backspace and will rub. Toyota/Nissan/Isuzu and some Mitsubishi trucks from the late '70s-late '80s also have the correct belt pattern, and did use narrower wheels, but they used a slightly deeper backspace. Thsi may cause issues with rubbing on left hand turns.
Bill Burmeister
ggfossen #695905 11/18/2010 2:50 AM
Mine were salvageable with mild sand blasting followed by powder coat. Take a peek into the picture book below. They aren't perfect but pretty good
Brian
Slinger, WI
'37 3/4 ton (grandpa)
'11 3/4 ton (grandson)
http://picasaweb.google.com/lh/photo/4xMv20nIhYF_AUPgEkRiFQ?feat=directlink
AUWING #695924 11/18/2010 3:51 AM
Bill,
I'll take one of the originals with me when looking about the yards. That should make it easier. I think I will also do a template, and a backspace guage of wood; something I can carry around the lot.
Brian,
That's a nice old truck. The wheels are the same as mine. Eventually, I will sandblast and then paint with urethane, but I need something in the mean time.
