2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | I have a '39 3/4 ton pickup with the original wheels. It will take a lot of work to make the old wheels clean and useable. Does anyone know from what newer trucks I can get wheels that will fit? How late the '39 bolt pattern was used? Maybe where I can get cheap wheels??
Gary | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | One way to use the original is to have them powder coated. That works great.
Monroe McKill
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Are you talking about single piece wheels or multi piece? If they are multi piece and they are badly rusted, they should be junked. | | | | | Joined: Jun 2010 Posts: 188 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 188 | So What is the bolt pattern? By newer do you mean modern or just newer stock type. | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | To all,
The originals are single piece artillery type. I think they are salvageable, but I want to install a set of later model OE steel wheels so as to make the finished chassis a roller. I need to move it in the shop. The originals will take some time and work for which I am not yet equipped. I have one that is a plain steel rim of recent build (perhaps from the 80s), but I do not know from what vehicle it came.
The current original wheels are 15" with six lugs, and whatever the standard spread would be for a '39.
I think one of the more recent Toyota rims will fit, but I do not know which. I also suspect that Chev used the same bolt pattern into more modern times, but I don't know on which trucks.
I have tried to find swap charts, but to no avail. I will check with the local tire place later in the week, but had hoped to have enough ammo to scronge the junk yard first.
Thanks.
Gary | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | You are correct. Toyota and Chevy wheels into the late 1980's are the same six lug pattern. To avoid steering problems, get the narrowest wheel you can find and/or make sure the offset doesn't put the tire into anything. I'm guessing you will be looking in salvage yards as a source. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Summit Racing has a great selection of after market wheels.I would look there first. | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Yes, either salvage yards, or tire shop take-offs. Cheap is the word of the day...or life time. I need to stick closely to the originals, as I intend to re-mount the tires onto them when I have them blasted and painted, and whatever else has to be done to them.
I will check for late model chev and toyo.
Gary | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | I will poke around town on Friday, and see what surfaces. Les Schwab may have some reasonable take-offs, and we have a couple of salvage yards.
Thanks, Gary
Last edited by cletis; 11/18/2010 7:00 AM. Reason: Removed response to parts offer
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1987 is about as new as you can go on Chevrolet wheels, the later trucks use a much deeper backspace and will rub. Toyota/Nissan/Isuzu and some Mitsubishi trucks from the late '70s-late '80s also have the correct belt pattern, and did use narrower wheels, but they used a slightly deeper backspace. Thsi may cause issues with rubbing on left hand turns.
Bill Burmeister | | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Mine were salvageable with mild sand blasting followed by powder coat. Take a peek into the picture book below. They aren't perfect but pretty good | | | | | Joined: May 2009 Posts: 132 'Bolter | | 'Bolter Joined: May 2009 Posts: 132 | Bill,
I'll take one of the originals with me when looking about the yards. That should make it easier. I think I will also do a template, and a backspace guage of wood; something I can carry around the lot.
Brian,
That's a nice old truck. The wheels are the same as mine. Eventually, I will sandblast and then paint with urethane, but I need something in the mean time.
