7 members (kades51, Southerntruck, Gray_Ghost, Bill Hanlon, Otto Skorzeny, JW51, MRMEROTH11), 82 guests, and 1 robot.
Topics128,133
Posts1,056,396
Members48,441
#694848 11/14/2010 6:06 PM
Has anyone discovered a good tool for removing the right side rear axle C clip?
I got the left one pretty easy but the right is somewhat more difficult.
Suggestions beyond patients of Jobe and dexterity of an Octpus please....
Riding in the Passing Lane
They just fall out when I do them. A magnet on a rod helps. I use that going back.
1972 Chevy c10 Cheyenne Super
Push the axle in and it will fall off
Tommy
59 apache 1/2t
261 short stepside
I know thats whats i thought too.... But this one isn't. It's like the gear is too far in not letting the C clip clear.
Still fighting this. It is like there may be some build up on the axle not letting it slide through the gear enough to allow the "C" clip to slide off. I have tried using a large common screw driver to slide in the "C" clip grove and force it inward but still no luck. The "C" clip does spin on the axel freely and axle turns with no problem but the "C" clip just won't come off.
I guess this is the fun part of old trucks right?
can you push the axle in some more? the clip should come off, do you have the brake drum off? if not take it off and the axle may go in further, other than that don't have any idea.
Tommy
59 apache 1/2t
261 short stepside
Try wacking the center of the axle with a hammer. It could be some burrs built up on the splines or crud.
Finally got the C clip out. Had to use a long common screw deiver slipped inside the C clip slot and prying on it while i hit the axle inward. The C Clip was then binding on something and I tapped it and it popped right out. Never did find what the problem was but when I reinstalled it just slipped right in place.
I anyone interested in pictures they are posted at
http://www.northtexasroadrunners.com/gbgallery59.html
Thanks guys for your help.
