| | | Forums66 Topics128,109 Posts1,056,240 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Has anyone discovered a good tool for removing the right side rear axle C clip?
I got the left one pretty easy but the right is somewhat more difficult.
Suggestions beyond patients of Jobe and dexterity of an Octpus please....
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | They just fall out when I do them. A magnet on a rod helps. I use that going back. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | Push the axle in and it will fall off
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | I know thats whats i thought too.... But this one isn't. It's like the gear is too far in not letting the C clip clear. | | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Still fighting this. It is like there may be some build up on the axle not letting it slide through the gear enough to allow the "C" clip to slide off. I have tried using a large common screw driver to slide in the "C" clip grove and force it inward but still no luck. The "C" clip does spin on the axel freely and axle turns with no problem but the "C" clip just won't come off.
I guess this is the fun part of old trucks right? | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | can you push the axle in some more? the clip should come off, do you have the brake drum off? if not take it off and the axle may go in further, other than that don't have any idea.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Try wacking the center of the axle with a hammer. It could be some burrs built up on the splines or crud. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2009 Posts: 26 New Guy | | New Guy Joined: Dec 2009 Posts: 26 | Finally got the C clip out. Had to use a long common screw deiver slipped inside the C clip slot and prying on it while i hit the axle inward. The C Clip was then binding on something and I tapped it and it popped right out. Never did find what the problem was but when I reinstalled it just slipped right in place. I anyone interested in pictures they are posted at http://www.northtexasroadrunners.com/gbgallery59.htmlThanks guys for your help. | | |
