2 members (Bill Hanlon, 1 invisible), 62 guests, and 1 robot.
Topics128,049
Posts1,055,679
#694527 11/13/2010 12:33 PM
Looking for pics or drawing's of the proper location for the lower fender braces on/for my 54 Chev panel.
Len
layback
Front or rear? On my 52 panel REAR there is a short round brace that attaches to the back/bottom of the fender and goes to the chassis. Once you stick the brace there its sort of easy to figure out.
Not sure about the front but I believe you have one that attaches at the back of the (down at the bottom of the cowl area) and it also goes over and attaches to the chassis.
Do you have acess to an assembly manual? I'll check mine when I get out to the shop and see if it shows it. Maybe ai can get my wife to scan it!!
Lenny, I checked my assembly manual and it does show the front fender brace at the rear of the front fender at the cowling. I was WRONG ABOVE about it fastening to the Chassis.
It does fasten to the lower lip of the fender but goes what looks like Vettical...then against an anti-squeak pad then put the bolt through it.
My wife will be back after lunch and I'll get her to scan a the pic and see if I can post it here. If not, I'll send it to you in an email.
Excellent, I don't think the braces attach to the chassie at all not sure but i am thinking they come back to the body only.The body mounts do all the work and the body just wobbles around on the chassie.
Len
layback
Lenny I have the page of the assembly manual scanned but do not know how to attach it here so I'll have to send it in an email.
You can send me your email address and I'll pop it back to you.
My address is [email protected]
Alvin,
It you want to mail the scan to me, I'll post it here.
Thanks Tim. I sent it to you just a few minutes ago. Hope this is what Lenny is looking for. If not, back to the books!!
Great guy's thanks, now it's the rear fenders, is there a brace front and back or just the back.
Len
layback
...on my 52panel there is on brace on the back of the fender. It bolts to the bottom of the fender lip and then goes to the chassis. They are short round rod type braces. Maybe the 54 are the same.
Good , I was given a bunch of these rod's a few years ago and that has been part of my trouble ,I have to many.I'll do some matching up and should be able to take it from there, thanks again
Len
layback
