MY OBJECTIVES: I want To retain the 235/6 and some day push it to
200-plus horsepower keeping it in the 50s era. The 235 came from a car
235 PG. I have had a Patrick's 3:55:1 Kit put in my rearend (the surgury
wasn't to bad). Now my delema is I want to swap out the tranny, I have a
number of options here, but the closed driveshaft is my big problem. I have
about 1K into it and really don't have the resurces to start over, but may
half to. I already know about Patricks Tranny kit. I E-Mailed him and He
called me that evening {what a fine man},to fined out if he know of a way
to alter the rearend to make it a open driveshaft. We talked along time
about the benifits of the Tourch Tube set-up on the 53 Chevy and that I
should order His Kit for the stock tranny, Understandably.I am looking to improve highway speed with less stress on the
engine, and good off the line take off with good higway speed. I am not
really looking to hotrod it. The A-833 new process Trans seems for me to
be the way to go, exept on one of ower snow days here in Colorado, granny
would be nice, and the tourch tube. Refrence: Grabbing for Gears Beyond
High/Feb 2001 by Jim Richardson in Custom Classic Truck magazine In the
artical its refuring to a late 50 PU that already has a open drive shaft.
I got a rusted out 49 Chevy PU witch had a open driveshaft in it
(car,3/4 ton, but not stock), I don't know, including a driveline, and
dissassembled the hole truck. The front housing on the 49 rear end
#NK1006* and the #3707340 D 1 has the same 10 bolt set (front of pumkin)
up as the tourch tube (53)# LU 6 22 both #s are in the same spot on the
output housing passenger side between 2 of the 10 bolt holes. The #s on
the 49 pinion shaft 3707341-10-39-GM 1 G.C. 10 54. The #s on the ring
gear inside the axel are 3697702 GM 10-39 9 54, 3.90 gear ratio.
The ? Could I swap there output (carrer) side of the pumpkin
retaining the Patrick's pinion gear and set up inside saving me $ to
shorten the driveshaft to put in a open driveshaft. My mechanical abilitys
are abit limited on trannys, and gearing in the pumkin but I have patienceThe ? Could I swap there output (carrer) side of the pumpkin
and time.
Do I also have a option of having the Tourch Tub shortend ,Some How ?.
*All info I have gotten is that NK# comes up as a Buick #,71-72 La
Sabe The NK looks like Some one alterd it.
Any help on the Closed Drive Shaft (tourch tube) ? would be most
appreciated.
Thank you
eazy e & my 53
Ernest E Simkins
[email protected] :confused: [email]undefined[/email]
