1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 7 New Guy | | New Guy Joined: Sep 2010 Posts: 7 | Does anyone know any way that I can repair a cut coolant temp gauge sender? it was cut in my truck when I got it. I swapped a 350 into the truck and I would like to run the stock gauges in the truck and need to figure out the coolant gauge. I saw a company sell new but I would like to try and avoid that to keep the same rustic look | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | They are filled with a gas so not repairable. You can get a new one from the sponsoring vendors. Jim Carter, American Classic and others. | | | | | Joined: Oct 2007 Posts: 63 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2007 Posts: 63 | Agree with vern, if it is a mechanical gauge, the line is filled with gas once damaged throw away unfortunately. regards andrew | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Any of the companies that are rebuilding gauges can fix a cap tube. It usually costs more than buying a new gauge. | | |
