| | | Forums66 Topics128,081 Posts1,056,074 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | I sent Jim Carters a photo of my rear motor mounts and they said they havent ever seen them. I have a 1946 one ton GMC with a 261 engine that has been replaced from the original 228.the transmission is a 4 speed and has a 11" clutch.The rear motor mounts are round cone shaped rubber bushings housed in a steel housing that bolts to the crossmember in the frame.If anyone knows where I can find replacement bushings for this rear motor mount I would be forever greatfull.I tried the search page but had no luck,please help I do not want to reuse these as they are in poor condition Thans again for your help | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy amabolter, how about you share those pictures with us? Lest We Forget. | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | just posted pix in photobucket | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | What you describe sounds like what I took out of my truck and replaced with the original style. If you want mine, that is if I can find them you are welcome to them. I'd like to see the picture, where is it? Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I have an NOS set of the mounts I believe you are looking for. Send me a private message if you are interested. Here is a link to pictures of my mounts.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Nov 2005 Posts: 1,554 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,554 | That's what my old mounts look like, I'm not positive if I still have them, go with those NOS mounts above. Dave 1941 Chevy"First rebuild - complete!"Follow the story in the DITY1941 GMC resting peacefully 1946/1947 Chevy Street rod on s10 frame complete 1945 GMC panel truck in line for restoration 1941 Plymouth stock complete 1941 GMC COE in restoration processRead his Project Journal1941 Chevy Coe uncertain future resting now
| | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | just sent Dave a PM. That is the mount I am looking for.Does anyone know what year these were used?Thanks for your reply By the way pictures of truck on photobucket at andy3456 album let me know if you are able to veiw them,thanks Andy | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | My parts book lists these for: 1937-53 "extra heavy duty mount"
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Pre 68 dave I am looking for an original set of rear mounts for a 41 228 engine. These are two pieces with one mounting to the housing and the second going into the first one but mounting down into the cross frame . You don't have by chance? Doug | | | | | Joined: Oct 2010 Posts: 91 Shop Shark | | Shop Shark Joined: Oct 2010 Posts: 91 | try obsolite chevy parts.com they have many hard to find parts for old chevy and gmc trucks | | | | | Joined: Mar 2010 Posts: 64 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 64 | Thanks, will try them. Doug | | |
