1 members (Gray_Ghost),
79
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | So, let's think about this...........The braces have to be in place above the headliner cardboard with the button pins installed and bent over, before installation can occur. You can't bend the tabs over with the headliner installed. So you can't install the buttons after the cardboard goes up. So Tim's premise may be correct, in that the mini-bows and buttons are part of the 2nd piece of headliner and therefore it's components (buttons and mini-bows)don't have part numbers. | | | | | Joined: Dec 2005 Posts: 2,557 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 2,557 | Do the panel trucks have the same braces in the headliner ? I'm sorry,I had to ask !
Tim 1951 3100 Chevrolet1951 Chevrolet Suburban CarryallImage"A house is built with boards and beams. A home is built with love and dreams." "Look deep before you leap !!!" / "Everything is Everything" "If I say a mouse can pull a house, hitch him up"
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Tim, this is what I found when I got my 52 panel. I could be missing something as this is the condition when I got it. It had the matrial shown stuck to the roof between the "bows" you see. It had all been pulled down but one or two strips. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0019.jpgThis is a piece of the original material showing both the back and the face side.... just in case someone is interested. http://i140.photobucket.com/albums/r19/LutherParris/52Panel/000_0020.jpg
