| | | Forums66 Topics128,155 Posts1,056,868 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 24 | I would like help decoding the vin and engine size on my GMC truck. Although the grille has a 350 emblem, it has a 6 cyl. Flatbed dually Tag reads as follows: Vin:353 c t 1014 Gross hp:140 @3600 Net hp: 127 @3400 Gross weight:16000 Combination weight:32000
Any help would be appreciated. I just bought it.
What engine options were available? Thanks for any help
| | | | | Joined: Jan 2008 Posts: 4,962 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,962 | The engine would be a 270 cu in. A 347 cu in V8 would have been available as an option. | | | | | Joined: Aug 2008 Posts: 82 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 82 | The 350 emblem doesn't refer to the engine or engine size. It's a 350 "series" truck.
I *think* it's also called a 2-ton, but somehow I often get that wrong.
There's a Low Cab Forward version of a 350, but I think the "c" in your VIN means it is a conventional. And, yours should have a ~155" wheelbase.
I also think there is an "8" in the serial if it came with the V8, so the sixer is what your truck rolled off the line with.
Probably has a 6.17 rear end.
Those are my guesses.
1956 Chevy 3600 Dually
| | | | | Joined: Apr 2008 Posts: 24 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2008 Posts: 24 | Great, Thank you all very much for the information. | | |
