3 members (sron48, Otto Skorzeny, 1 invisible), 89 guests, and 1 robot.
Topics128,154
Posts1,056,856
Members48,456
I would like help decoding the vin and engine size on my GMC truck.
Although the grille has a 350 emblem, it has a 6 cyl.
Flatbed dually
Tag reads as follows:
Vin:353 c t 1014
Gross hp:140 @3600
Net hp: 127 @3400
Gross weight:16000
Combination weight:32000
Any help would be appreciated.
I just bought it.
What engine options were available?
Thanks for any help
The engine would be a 270 cu in. A 347 cu in V8 would have been available as an option.
The 350 emblem doesn't refer to the engine or engine size. It's a 350 "series" truck.
I *think* it's also called a 2-ton, but somehow I often get that wrong.
There's a Low Cab Forward version of a 350, but I think the "c" in your VIN means it is a conventional. And, yours should have a ~155" wheelbase.
I also think there is an "8" in the serial if it came with the V8, so the sixer is what your truck rolled off the line with.
Probably has a 6.17 rear end.
Those are my guesses.
1956 Chevy 3600 Dually
Great,
Thank you all very much for the information.
