9 members (walter74, Sjm, Wooley, SmalltownTRKGuy, baldeagle, Sjm, Hotrod Lincoln, cmayna, Woogeroo, 1 invisible), 333 guests, and 8 robots.
Topics128,165
Posts1,057,089
Members48,463
Has anybody ever put a chevy car torque tube rear in an AD 3100?
I have available to me an original rear from a '50 chevy 2 door fastback. It's a 3 speed manual, so I believe the ratio would be 3.73. too bad it wasn't a powerglide car, I think those are 3.55.
I haven't had a chance to measure anything, but was wondering if anyone has done this and how feasible it is. I will hang on to this piece for a future project if it is worth swapping into a pickup.
Steve
'49 3800
'52 3600
'57 3100
I may be wrong, but I believe Ive heard of people swapping the rear ends from a car into a truck to get a higher driving speed. Someone will step in shortly and correct me or agree. Good luck!
My 1953 Chevrolet
1947.1 Gallery
That's the whole idea.... grin
Steve
'49 3800
'52 3600
'57 3100
I don't think it'll work. The passenger car had a shorter wheelbase, do the tube will be too short to align properly. Also, the stick shift passenger cars had 4.11 gears, so there's no advantage there unless you can find a 'Glide unit, though that probably won't bolt up the the truck trans. The passenger rear also has smaller axle shafts and brakes.
If you want a higher gear, going to an open drive would be the best overall option.
Bill Burmeister
The swap you are speaking of will net you about 5 mph more speed. On the other hand, a Power Glide rear end will give you 10 mph more speed.
Other things to consider: the car axle will be a 5 bolt axle and your truck now has 6 lugs.
I did this swap with a Power Glide rear end in 1983 on my 37 and it does make a differnce (I now have a T-5 and open drive line). Now, however, the easier choice for you, in my opinion, is a set of 3:55 to 1 gears for your rear end. Then, there are no other issues to contend with.
Joe smile
Thanks for the input...I'll pass it up then.
I figured if it was close to being a bolt up I would get the rear...it was free. I don't even have a 3100 to put it in right now, I just seem to be thinking about three projects ahead all the time and like to accumulate parts.
Steve
'49 3800
'52 3600
'57 3100
Ex Hall Monitor
Ex Hall Monitor
I don't know about a 50 model but my 38 Master has the 3.73. The Master Deluxe had the 4.11. I believe you can buy rear end gear sets that will give you a 3.55 ratio.
