1 members (Cletus1950),
65
Mod | | | Forums66 Topics128,151 Posts1,057,000 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | I'm a newby to Stovebolt and old vehicles in general. I've got a 37 Chevy 1/2 Ton pickup that has 5-lug 15" rims from a 69 Camaro (I don't know the rim width). Trying to replicate narrow tire stock look as best as possible using existing rims. Any recommended tire sizes and makes?
| | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Mike I looked at a lot of options and settled on Yokohama 215's. It was a cinch once I discovered they have a matching snow tire. Click into the picture gallery below and you'll see them installed http://www.yokohamatire.com/tires_commercial/ry215.aspx
| | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Thanks Brian, great looking truck too. Looks like you have 15" artillery wheels. Can you tell me the tire height and rim width of your truck? | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Joe, The previous owner dropped in a 307 engine and transmission from a 69 Camaro, so I believe he did swap out the axles. It definitely has 5 lugs and 15" rims. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Might also have a look at Coker Tires - they make modern radials with " old style " look. | | | | | Joined: Jan 2010 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 55 | Thanks Mike - they are 15" artillery wheels. Rim width is 5.5 Overall tire width is 7.7" and height is 29.4", Tall & skinny | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | Can anyone help me translate this? According to the chart at the link below, a '37 1/2 ton Chevy PU would have had a 4.00E rim base with 6.0-16 4-ply tires. Does this mean it would have have had 16" dia, 4" wide rims and tires with a 6" section width? If yes, does anyone know the tire height that would convert to? Any ideas where I can find modern (i.e. not split) rims of those approximate dimensions? Thanks, Mike http://chevy.oldcarmanualproject.com/chevyresto/3734.htm | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the 4.00E indicates 4" rim width, which you'd have a hard time finding affordable tires for, and the E has to do with the bead shape, which won't take radial tires .... 600x16 was pretty well standard back then for any car or light truck, I'd guess 28-30" height
I'd find 50's or 60's 5 stud GM rims, which will be 5", 5.5" or 6" width and then you've got a good selection of tire sizes, radial or bias, to get the right look
Bill | | | | | Joined: Nov 2010 Posts: 97 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 97 | | | |
