1 members (Hotrod Lincoln), 104 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#693791 11/10/2010 10:47 PM
Instead of using Stainless steel, why can't we use copper for fuel lines?
Craig
over a period of time, copper "work hardens" and cracks
Copper nickel is a good (much better I think) and easy to work with alternative to stainless, and most anything is much better in the long run than plain copper, as mentioned above.
I've used a lot of copper nickel line on my truck, here's some info
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=669101#Post669101
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I've used copper with excellent results, but:
1. use Adel clips to prevent any vibration from hardening it
2. large radius bends only
3. inspect it every 2 years
It's also far easier to repair with a compression fitting and hand tools than steel.
