7 members (Donf, JoeDude, 48jim1ton, gswbbc, frogfarmer, Gdads51, Gib70), 109 guests, and 3 robots.
Topics128,035
Posts1,055,528
Members48,425
#693624 11/10/2010 5:41 AM
Will a head from a 53 235 fit on a 54 235?
J M Offline
A 54 235 and a 53 235 are two different engines, and I don't believe that the heads will interchange.
Jim
J M #693638 11/10/2010 6:41 AM
The 1954 has 18 bolts, the 1953 may, before that all are 15 bolts.
Both the splash and full pressure 235 heads used in 1953 will fit the 1954-62 engines. The only problem is the head is not drilled for the four bolt valve cover.
I have used them many times.
My Blog
I saw a post on another site that drilling the holes can result in a hole into the water jacket. Is that correct Dave?
1951 1 Ton Completed
I would not be surprised.
I once drilled a 216 head for a four bolt cover and I hit water. I used studs in that case.
I have not drilled a 53 head, I just use them on jobs where the customer wants to use a 216 valve cover for a stock look.
My Blog
