| | | Forums66 Topics128,108 Posts1,056,567 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 11 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Nov 2009 Posts: 11 | I saw an article in an antique car publication about a fella that had a leaking banjo bolt on an old MG top oiler line that he could not get stopped. He found a bonded pressure sealing washer through McMaster-Carr Supply Co. that did the job. This was a steel washer with a rubber or neoprene backing bonded to the washer. When you put it under a bolt and tighten it down the rubber expands and seals the leak. Their on line catalogue is www.macmaster.com. Looks like they have all types of bolts, fasteners and washers that could be handy to us stovebolters. Tex the Old Stovebolter
what,me worry?
| | | | | Joined: Sep 2010 Posts: 222 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 222 | McMaster Carr is a real standby for scientific researchers, I use them all the time for fittings for my lab work. Expect top quality and high price. smallparts.com is another good option for similar supplies. Cheers, N | | | | | Joined: Jul 2004 Posts: 2,989 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 2,989 | I've ordered from them a number of times. They've got just about anything, and you can usually have it sitting on your doorstep in only a day or two. | | |
