8 members (55shaker, 68ironhead, Ol'55, 3B, baldeagle, Otto Skorzeny, gswbbc, 1 invisible), 99 guests, and 2 robots.
Topics128,039
Posts1,055,473
Members48,424
#691793 11/04/2010 3:03 AM
Just took the carb off my truck to rebuild it.Its a 58 GMC with a 270,it has a Zenith carb.Where are you guys getting your kits at?I found a few online but didnt know if one or the other was better quality.Ive rebuilt a few carbs in the past,mostly 70s era Autolites.Anything inside of the Zenith gonna suprise me or is it pretty simple?Thanks in advance for the help.
Jeremy
581ton #691808 11/04/2010 3:39 AM
I've found that the local parts store has or can get carb kits for any that I have rebuilt going back as far as 1949. You might have to find somebody in the store that still knows how to read from a book.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I got a kit from NAPA.
One thing that will surprise you is the aluminum cup on the pump. The kit comes with a rubber one.
Cletis #693420 11/09/2010 4:35 PM
I have a question about that also.The hole that the rubber goes into has a cap that the old rod hooked into.Do I need to take that out of the bowl assembly or put the new rubber type pump over that cap?The cap seems to be in there pretty good .Another question.The original throttle body gasket is very thick and the new one is thin.The old gasket has a metal grommet that helped space the carb sections apart,the new gasket doesnt and there is a brass pin that goes between the throttle body and the bowl assembly and with the thinner gasket they dont quit go together all the way.Thanks again for all the help and fast replies.The experience and knowledge you guys share is invaluable.
Jeremy
581ton #693563 11/10/2010 3:06 AM
I cant find much about these carbs online.You would think the kit would come with some sort of instructions other than a sheet with all the parts on it.
581ton #693593 11/10/2010 4:10 AM
That isn't a "cap". That is the old, stuck pump piston. It must come out.
edit: If you have the aluminum piston out, There is a valve in the bottom of the hole. It should not be removed.
Cletis #693599 11/10/2010 4:19 AM
Thanks Cletis,that makes me feel better.Any idea why the gasket is thinner and dooes'nt have the little metal grommet?
