| | | Forums66 Topics128,059 Posts1,055,825 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Would the PTO for a 39 boom recker be the same as on my 46 chevy 1.5 ton?  The 39 has the torque tube drive shaft but doesnt seem as though that would be an issue. Here are the numbers D297 Chevy Bowtie 590474
| | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy CAJUN CRAW FISH, as long as both transmissions are the same [little flip lever for reverse lockout] then the p.t.o. should interchange, hope that helps. | | | | | Joined: Sep 2006 Posts: 126 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 126 | Latest info is that the truck was built in 37 and the boom setup was 39 and Here are the numbers on the trans
D297
Chevy Bowtie
590474 | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Drain the tranny, pull the side cover off the transmission in question and look at the gears and 1, count the teeth, 2, check to see if they are at the front or rear of the opening, 3, check to see if they are spur or helical gears and idf so are they LH or RH helix. (look at your thumb) Then check the PTO your asking about and you will have your answer. If it won't fit you can use the information gathered to get a new PTO. Model information on a transmission that age will not be useful as the books/programs don't go back that far but a good PTO specialist can fill your order using the information I've shown you here. | | |
