6 members (frogfarmer, Gray_Ghost, dunfire, Otto Skorzeny, jay d, 50Chevy3100), 81 guests, and 3 robots.
Topics128,056
Posts1,055,804
#693518 11/10/2010 12:09 AM
Would the PTO for a 39 boom recker be the same as on my 46 chevy 1.5 ton? headscratch The 39 has the torque tube drive shaft but doesnt seem as though that would be an issue.
Here are the numbers
D297
Chevy
Bowtie
590474
1946 Chevy 1.5-Ton Flatbed
Photobucket
Old Big Trucks are built to last.
3B Offline
Hy CAJUN CRAW FISH, as long as both transmissions are the same [little flip lever for reverse lockout] then the p.t.o. should interchange, hope that helps.
3B #693542 11/10/2010 1:43 AM
Latest info is that the truck was built in 37 and the boom setup was 39 and Here are the numbers on the trans
D297
Chevy
Bowtie
590474
Photobucket
Drain the tranny, pull the side cover off the transmission in question and look at the gears and 1, count the teeth, 2, check to see if they are at the front or rear of the opening, 3, check to see if they are spur or helical gears and idf so are they LH or RH helix. (look at your thumb) Then check the PTO your asking about and you will have your answer. If it won't fit you can use the information gathered to get a new PTO. Model information on a transmission that age will not be useful as the books/programs don't go back that far but a good PTO specialist can fill your order using the information I've shown you here.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
