8 members (68ironhead, lumbersawyer, 48jim1ton, Woodcmiami, 3B, J Lucas, Ponchogl, 1 invisible), 97 guests, and 0 robots.
Topics128,049
Posts1,055,553
Members48,425
#693212 11/08/2010 11:37 PM
I have a 66 292 that has the NOX System for emissions. I took my Heater Box apart over the weekend, and I notice that the Tune Up Decal that is located on the cover, could use replacing. I looked through my supplyer catalogs, but did not see any. Does any one know if someone reproduces the Tune Up Sticker for the 292 emission motors?
Thak you for your help
SD66Burb #693385 11/09/2010 11:29 AM
This company makes 99% of all the decals out there Great quality and 100% oem stock material.
http://osborn-reproduction.com/
What is NOX?
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
Modelman #693400 11/09/2010 2:34 PM
Betcha NOX isn't a nitros-oxide system in that old truck
That is what it means now.
gazim #693405 11/09/2010 3:23 PM
nitrous-oxide is "NOS" [N2O] although rodders like NOX - what SD66Burb is referring to is actually "NOx", a different nitrogen oxide commonly known as smog
nobody would be reproducing anything relating to 60's Calif-only pollution control, pretty limited market wink
squeeze #693446 11/09/2010 6:55 PM
If you can find a good pic of the decal you shouldnt have any problem getting one made locally.Most sign shops can make decent quality decals now.
SD66Burb #693485 11/09/2010 9:23 PM
I figured that this would be a shot in the dark to find. Mine is still in tact and complete, but it has a dark film on it, or it may have just discolored. Any ideas what would be a good thing to try to clean it with?
No, no NOS here. I'm afraid that poor 292 might not be real happy with it.
Thanks again for your help
SD66Burb #693494 11/09/2010 10:02 PM
Apprentice
Apprentice
NOX decals were a result of Californina-mandated NOX devices that were required to be retrofitted to 1966-1970 cars and trucks registered in Calif. There were several different versions of NOX devices, but all were fundamentally designed to disable the vacuum advance mechanism as a way to reduce NOx emissions before the invention of the EGR valve. The most simplistic (and cheapest) NOX device was a set of rubber caps to plug the vacuum advance cannister and feed port and a sticker for the dashboard that said "Don't drive over 60 MPH". I am not making this up. The lack of vacuum advance could cause overheating at part throttle under load.
More sophisticated NOX devices actually incorporated a temp sensor that would re-enable the vacuum advance if the engine overheated. I have one of these in the barn someplace. It came on my 1966 442 that I bought in San Jose.
Starting with the 1970 model year, GM installed a system called Transmission Controlled Spark (TCS) that disabled vacuum advance unless the trans was in high gear. This essentially did the same thing as the NOX device. Of course, all of these devices went away when EGR showed up in 1972 on CA cars and in 1973 on 49-state cars.
As an example of how idiotic the emissions inspectors were at the time, I had a co-worker who had replaced the vacuum advance distributor in his Dodge van with a fully mechanical advance unit. The Calif emissions inspectors made him remove the mechanical advance distributor and reinstall a stock vacuum advance unit just so that he could install a NOX device to disable the vacuum advance. ohwell
Joe Padavano
joe_padavano #693498 11/09/2010 10:28 PM
I've got one (in the original box),including the
decal.Anyone interested in it?
- Doug
'60 Anglia
'67 MGB GT
'74 MG Midget
'78 B210
1960 Apache 30 Panel
