Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (baldeagle), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#693041 11/08/2010 11:46 AM
Need help on where to connect the throttle cable on a 216 53 5 window. Not sure what type of carb I have,
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #693083 11/08/2010 3:20 PM
Here is how my throttle connection is done on my W1 Carter.
my carb setup
1946 Chevrolet 1/2-ton
More pix on Photobucket
Big Tee #693163 11/08/2010 8:09 PM
The connection for a Rochester B is the same as a W1 Carter. The throttle cable keeps the rod from falling off the carburetor arm. The cable uses the same bracket as the choke cable. Look at the picture in the post above. If you have the original carburetor on your truck it would be the Rochester B.
don stocker #693236 11/09/2010 12:36 AM
Outstanding info guys, thanks
Charlie
1953 5 Window
2006 Chevy Colarado
