| | | Forums66 Topics128,277 Posts1,058,441 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | I just removed the door hinges from the cab. I had to use the angle grinder on some of the bolts. Also, the cages nuts that the door hinges bolt into are shot. Anyone know where to get replacements for the caged nuts? Do I need to make them? Where can I get the bolts? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | Mar-K has them #110683 about 2 bucks ea, not sure about bolts but one of the suppliers will have them .... or you could use some Ford ones, same thing .... either way, some of those are hard/impossible to weld in with opening up some panel Bill | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Great, I found them on the site! MAR-K is kind of expensive. The Ford ones are pretty cheap. | | | | | Joined: Dec 2005 Posts: 406 Shop Shark | | Shop Shark Joined: Dec 2005 Posts: 406 | McMaster has these too, http://www.mcmaster.com/#captured-nuts/=9mxjh9 They don't have as much adjustment as the originals, so if you use them, be sure to weld them on right the first time. | | | | | Joined: Jan 2010 Posts: 150 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2010 Posts: 150 | Thanks. I haven't written off MAR-K. My Dad lives in Del City and my Mom in Edmond. It may be cheaper to get them to pick them up and mail them to me.
